PUGGY 407 ABS/ESP ECU ANYONE HAD PROBLEMS??
gazzas c5
Unread post by gazzas c5 »
Hi Folks
My puggy 406 se hdi 2.0 has esp light on dash ,had it plugged in diag machine wont communicate with abs ecu,also states fault with rear left wheel speed sensor which has been checked out ,that's fine.
BUT Esp light still showing ,is a 2nd hand one easy to change over?
Any ideas or tips please folks?
Cheers
Gaz
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
x 3298
Re: PUGGY 407 ABS/ESP ECU ANYONE HAD PROBLEMS??
Is it possible that the reluctor ring for the left rear wheel has failed (cracked or missing/clogged teeth)? If the ring has cracked that would mean it would be loose, and could spin at a different rate that the wheel itself. If it has missing/clogged teeth hat would produce a 'count' error. Either way, the ABS system would show a mismatch from that sensor.
The downside is that (if the hub is like that on a Xantia) the reluctor ring is part of the rear hub. You cannot replace the ring on its' own; you have to replace the whole hub.
