Battery terminal
froggy
- (Donor 2026)
- x 4
Battery terminal
Hi, my series 1 Xantia. just noticed that I can pull the positive wire out of the clamp , with ease ! my question is, should I be replacing the positive lead or is there a way of repairing the lead. ( I have tried to tighten the two screws on the battery clamp, but it is still very loose ! any advice gratefully received, Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
taffy
Re: Battery terminal
is it the origional battery clamp or is it an after market one which you put the wire in and tighten two screws?..if its the later and its not hold ing the wires properlt i would try strip it back abit more say an inch and hopefully ul have some uncrushed wire to guide in and hopefully it will work ok
the origional conectors can loose there lead and start to loose hold of the wires but normally an aftermarket one would cure this as its a bugger to do...maybe even consider using some solder into the clamp?
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
Mandrake
- x 695
If you can pull the wire out of the clamp easily get it fixed ASAP as it is a fire risk!
As long as the wire itself is clean and not corroded 3rd party clamps are the way to go as replacing the positive cables is not easy.
Less than £10 from halfords did the trick for me:
http://www.frenchcarforum.co.uk/forum/v ... 39#p391139" onclick="window.open(this.href);return false;
I tried a couple of other types but they didn't fit the wires. These have been on my car for 6 months with no trouble, and the quick release is quite handy when you're doing work under the bonnet.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
sparksie
- x 33
Hi
There is a very common misconception that "heavy duty" clamps are better.
Not so.
You should always choose the clamp that fits your cable. It should be barely possible to get all the strands into the battery clamp, with the screws out as far as they can go without getting lost. If you take them out, you can bet some of the strands of cable will come out the screw holes!
If you have the right size clamp for your cable, you'll find the screws get tight before the screw heads bottom out on the clamp.
If you simply have to use a clamp thats too big, find a way of filling all the extra space. Make a ferrule from copper pipe that just fits over the cable, or if really desperate, fold some of the cable strands back on themselves.
Don't use solder to secure high current cables. There MUST be a good mechanical fix, independent of the solder.
When passing high currents, solder (particularly modern low lead formulations) will crystalise and form a resistive join, causing heat, which exacerbates the problem, until eventually either the joint fails or the battery post melts!
Once you have a good join between cable and connector, then it can be a good idea to run some solder in, to keep moisture out and secure screws against vibrating loose, though even in seaside locations, this is really not essential.
Even so called "solder on" battery clamps should be a tight fit to begin with and get a further tighten with mole grips, or similar, prior to soldering.
This is my field and I often get called out to "no-start" situations, where the problem turns out to be shoddy high current leads!
OP, check your battery lead carefully. Heat from the loose connection may have made the insulation brittle, even some distance away from the bad joint. If it's a positive lead this would be a "Very Bad Thing", trust me!
Not so.
Sparksie
2000 Xantia 1.9TurboD
Mandrake
- x 695
Very true. When I was trying to replace my clamps I had trouble finding ones which would actually fit the size of the bundle of wires - most of the more heavy duty looking clamps simply had wire holes that were far too big and I didn't like the idea of too much packing.sparksie wrote:Hi
Not so.
The quick release type I used don't look very beefy and wouldn't normally be my first choice but the clamp that holds the wires is a very tight fit with plenty of adjustment so those wires aren't going anywhere. It clamps very securely to the battery post too due to the lever action when clicking it shut. (like a pair of vice grips) Looks a bit unusual but 6 months later still working perfectly, all for under a tenner...
Simon
1978 CX 2400
1978 CX 2400
