Xantia - Checking rear subframe mounts
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
I ha've got a clunky back end over bumps, how can the rear subframe mounts checked if they are OK or not ?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
Xantidote
x 5
Re: Xantia - Checking rear subframe mounts
Unread post by Xantidote »
Not a direct answer to your question, but a few years ago my Xantia had an annoying intermittent knock from the back end, which I eventually traced to the rear ride height being wrong. Somehow or other, the height corrector clamp on the anti-roll bar must have rotated slightly - I adjusted the rear ride height and not a murmur since. Until identifying the ride height as the problem, I had suspected the sub-frame bushes.
Martin
1995 Xantia TDLX (deceased :( )
VertVega
x 13
Unread post by VertVega »
I would suspect:
1. rear arm bearings
2. loose spare tire carrier
999. subframe mounts
