Car wouldn't start this morning even after trickle charging for an hour, then trying to jump start from the wife's Clio. Eventually went and bought a battery and fitted it. Car started fine, but when the battery was first connected, I heard the suspension motor whining for ages. It normally does this when I open the door but never for so long or so loud.
With the new battery installed and the engine running, I set the suspension to high. That worked fine, although there was a 15mm difference between N/S and O/S front. I then set the suspension to low and did a quick check. It seemed to be OK. I then tried to set it at normal but it wouldn't budge. The height settings didn't come up on the display. the service light appeared and the warning "Suspension fault, Max speed 55 mph" was displayed.
Biggest problem is, I have my daughter and two of her children arriving at the airport tomorrow morning, complete with push chairs and luggage, and the wife's Clio just isn't big enough for everything.
Any quick fixes?
