I have been running a Renault Clio 1.2 16V Rip Curl 5Dr Petrol Hatchback (2008) for over a year without issue, until now.
Recently I had my windscreen wipers on low/slow intermittent setting, then suddenly out of the blue they stopped in the middle of my windscreen.
I tried moving the stick down to try a faster setting and it also doesn't work.
The only way I can get my wipers to work is to set the on the fastest setting then they start moving quickly.
But as soon as I move the stick back up to the lower/intermittent setting the wipers stop (sometimes in the middle of the screen) and do not park/return to their start position.
I’ve also noticed now that sometimes when I leave the wipers set on the lower setting they tend to jerk a few cm every few seconds as if they want to move?
I am unsure what is causing the problem.
All I can think of is there’s something wrong with the wiper park sensor or maybe a dodgy relay or connection on the control stick?
I have had a look in the fuse box that is on the right side of the battery (under bonnet) to see if water had got in but it was dry as a bone. As I was worried the electrics may have got wet due to the ridiculous amount of rain we’ve had.
Has anyone had a similar problem. Any advice or help will be greatly appreciated!
