Tracker
xantiagreen
Tracker
Unread post by xantiagreen »
Xantia HDi 110 2001 hatchback
Tracker seems to go off when it wants and its loud, usually when I start the car first thing it sets off giving me the serial number then the number to call because its expired, how do I switch it off without causing another problem.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
forrozza
Re: Tracker
Unread post by forrozza »
on my C5, I think you just press the Trafficmaster button,next to your right leg twice (if thats what you are referring to) that goes between Manual or Automatic. Manual would turn it off completely, which is how I have mine,however if you get a problematic battery the darn thing turns itself back on again. You can press the stalk end button twice and you can then scroll thru the menu to select the volume level. with the sound option you then press the button again to drop the volume an increment at a time (10 down to 1)the lowest level you can have set as automatic is 1, you cant mute it. Hope this makes sense.
C5 2.0HDi 110 SX 2002.
Xantia 1.9TD 90bhp SX 2000 (Just retired and sadly missed)
BX14 TGE 1991 (Beautiful car, wrecked by boy racer)
