Have an esp asr light on my peugeot 407 hdi se
2004 plate, it's doing my head in also windscreen washers not working either, fuse??
Any info be much appreciated.
Cheers.
Gaz.
puggy 407 hdi se esp asr light staying on all the time HELP
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
Re: puggy 407 hdi se esp asr light staying on all the time H
In the absence of a more informed reply. You really need to read the fault codes with a diagnostic tester. The esp fault could be anything from a broken wire to a faulty abs unit. The washer is possibly a failed pump. You need to check that power is being supplied to the pump.
- Gibbo_Wirral
- My Cars: Peugeot 206 Sport 2L HDI
- Contact:
You need a Planet diagnostic. It could be one or more of half a dozen things causing the problem.
Check the Lexia map thread for your nearest member with the diagnostic gear.
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
