need rear calliper bolts Xantia R reg estate 1.9 diesel turb
andrewmhmusic
- New User
Hi all and thanks for a great forum. I have done he sheering off and successfully removing a rear calliper bolt stub from the swinging arm. Phew. Now could do with some new/ish rear calliper bolts. Anyone got some? many thanks, Andrew your friendly neighbourhood Andre Rieu style violinist/ mechanic
- x 5673
Re: need rear calliper bolts Xantia R reg estate 1.9 diesel
Andre Rieu is a mechanic? I would never have guessed that
Xantidote
- x 5
As some bolts get destroyed whilst they are being removed, there may not be many used spares hanging about, & I suspect you may have to order them through your friendly Citroen dealer. My guess is £3-5 each.andrewmhmusic wrote:Anyone got some?
Martin
1995 Xantia TDLX (deceased
citroenxm
- Fallen Hero
- x 70
Ive GOT SOME!
How many do you need?
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
and here is price and part No. from citroen
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000440526 CALIPER SCREW 1.98 GBP 2.38 GBP 2.38 GBP
Regards, malcolm.
citroenxm
- Fallen Hero
- x 70
Is that to assume they are still available malc? That's the important bit..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
citroenxm wrote:Is that to assume they are still available malc? That's the important bit..
well they are not showing as NFP = No F*'*i*n*g Parts
Regards, malcolm.
citroenxm
- Fallen Hero
- x 70
Then I need not get excited and need to trawl the mess to find them if they are still this cheap.
I'll wait till they are nfp and tthere's none left..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
dnsey
- x 19
They'll be the same as C5 ones, I should think - the calipers are almost identical.
- x 94
with an all families search they only come up as MK1 and 2 XANT's, and not C5'sdnsey wrote:They'll be the same as C5 ones, I should think - the calipers are almost identical.
Regards, malcolm.
citroenxm
- Fallen Hero
- x 70
NO C5 calipers are not the same, they are almost twice the size, WELL, the Rear Disks are twice the size as Xantia ones, I think the C5 clipers are wider, making the C5 Bolt LONGER.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
C5 estate rear caliper
4405 50
BRAKE CALIPER FIXING SCREW
10X125-150
XANT estate
4405 26
10X125-140
4405 50
10X125-150
XANT estate
4405 26
10X125-140
Regards, malcolm.
citroenxm
- Fallen Hero
- x 70
Thanks Malc.
Thought the C5 bolts were longer... but not a lot though..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
