Heater not working
forbsy36
Heater not working
Unread post by forbsy36 »
Hi all
Im new here and was hoping someone could help me out. Ive got a Citroen Xsara 1.9td MK1 1998 the problem is the heater has stopped working. It only ever worked on setting number 4 prior to it not working anymore. I have since changed the heater resistor pack and had the fan tested which is all in good working order, however this has not fixed the problem. Has anyone got any ideas as to what else it could be?
Many thanks.
citroenxm
Fallen Hero
x 70
Re: Heater not working
Unread post by citroenxm »
Plug terminals on the connetion TO the motor. The Brown 4 pin connection has a habit of bad connection.
Start engine, switch on the roatry dial, go under the dash and wiggle the connection to the blower. Try that!
If that does something remove the plug and clean up the connections..
A very sad...
1994 XM 2.1 d auto
forbsy36
Hi and thanks for your reply.
I have had a go at cleaning the connectors and while i was there i thought i would check the live line and there is no power what so ever!!
Any ideas anyone ?
Thanks again.
Was ment to say i have checked the fuse aswell.
