Xantia water in diesel light issue
mirafioriman
Unread post by mirafioriman »
The water in diesel warning light has been coming on intermittently recently. Today I've drained the water from the filter housing then serviced the car and replaced the fuel filter. This has made no difference it's just the same. Anyone got any ideas? It's a 1994 1.9d
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
Xaccers
x 188
Re: Xantia water in diesel light issue
Unread post by Xaccers »
If you disconnect the sensor wires does the light go out? Otherwise it's instrument panel out and remove the bulb.
PSA ditched the sensor a year later as it's not needed.
DIY sphere tool
mirafioriman
Thanks disconnection it is then
Xantidote
x 5
Unread post by Xantidote »
Mine's come on a couple of times in the last year, after being very well behaved for years. I drain a little fuel off into a jam jar but never see any water droplets, but the warning light then goes out, so happy again :-D
Martin
1995 Xantia TDLX (deceased :( )
Xaccers
x 188
My old 205's used to light up all the time, never any water in the fuel.
DIY sphere tool
mirafioriman
Well, now the sensor is disconnected and touch wood the light hasn't come back on since.
I have had to replace the starter motor today however as the existing one was close to dying permanently.
