Xantia – Leaking steering ram
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
After replacing the buses and the arm cover I found out that the ram is leaking ( LHM in the plastic cover). Can a leaking steering ram be fixed ? Any Citroen fixing kit? The part number is 4005A2
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 94
Re: Xantia – Leaking steering ram
Unread post by citronut »
service citroen do not show ram seals,
the only item they do list but not under Xant, for the XM ram is the seapage return rubber collar,
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
95640212 LEAK BACK UNION 6.43 GBP 7.72 GBP 7.72 GBP
it really depends on how much fluid is showing at this point to if the ram seals are/have failed,
it is normal to have a weep/some seepage at the rubber collar, but not a flow of citro blood
Regards, malcolm.
