xantia 1.9td cooling system
- boeingmech
Hi I have a 95 xantia 1.9td with a bit of a cooling problem,the engine takes a while to heat up and at max temp the gauge sits at about 85c but the heating inside the car is only luke warm,i changed the stat but that didn't change anything the bottom of the rad was cool this morning with the upper part warm the engine fans do not cut in, if it is a blocked heater matrix what is the best way of flushing it.
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 70
Re: xantia 1.9td cooling system
I need to sort one simmilar too, but what im going to do which you need to do VERY CAREFULLY as they will be brittle is remove the heater matrix feed pipe, but be very carefull they do break easilly.
Once off use a GOOD power full hose and BLAST the matrix out!
Only other thing to do is pipe one pipe off the cylinder head outlet at the gearbox end, and the other end is down the back of the engine at cooling system joint.. above the bottom engine mount
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
