Can anyone tell me if the black nylon fuel pipe running from rear to front for a S2 xantia hdi is 8mm OD and what is the best way to join them together? is it using brass compression fittings? what about push fits.
Also where can you buy the Citroen push fits to join onto the fuel pump in the tank and onto the diesel housing filter as i've looked on ebay and can't see them listed.
All the best Ade
