Xantia check strap removal
Xaccers
x 188
Unread post by Xaccers »
Is there a knack to removing the check strap from the back doors?
DIY sphere tool
Northern_Mike
Re: Xantia check strap removal
I'm not sure. If it's anything like the 306 I did, it's a door card out job, and a long, thin armed fiddle to undo two inner bolts before you can get it out. The drivers door on the Berlingo is noising up now, I can't face it!
addo
Sara Watson's Stalker
x 95
Unread post by addo »
You must first remove the glass and glass run channel, from memory.
