series 2 Xantia door open light
allanmc
Unread post by allanmc »
Hi, went out in the car today and the door open light and beaper sounding, opened and shut all doors still the same except after about 10 min. driving the beaper stopped I then stopped the car and the light remained on started up and the light and beaper was still going can soemone help please
regards
allan
Xantia 2.0i SX Auto, 1999
ACTIVE8
x 6
Re: series 2 Xantia door open light
Unread post by ACTIVE8 »
The beeper you can hear, is that the lights on beeper?
ACTIVA
allanmc
I will have to check that later I can say for sure the wee diagram for a door being open is lit.
allan
allanmc
Went to the car today opened and closed all the doors and the light on the dash went out so I think it must have been a bad connection
allan
allanmc
Last month I said the door open light and beeper was on when I was driving and that after a few days it went off, well a couple of weeks ago it started again when I was out, the next day I sprayed Plus Gas into all the locks and that seemed to fix it but today same thing happened door open light on, beeper going, and interior lights on after 5 min lights went out sprayed all the locks again but this time it didn't help hope you can.
Regards
Allan
xf1ref
x 12
Unread post by xf1ref »
I think that you have problems on the doorlock contacts for close door, or a bad connection on wire connectors.
I have no ideea how to find the doorlock with problems until it completely dies.
