It's ok or not. my xantia
fox01
Unread post by fox01 »
many day ago, i have got a problem about stop warning and overheat signal on dashboard.
but temperature is only 60 degree and oil temp. the same. the fan go to high speed and clutch air compressor is disengaged
what is the problem?
and the other, in my car have 3 coolant Sensor brown plug , green plug and blue plug
when i disengage brown plug (not start the engine/ ignition switch off) ,the fan go to high speed.
after that i engage brown plug ,the fan go to low speed
when ignition switch on (not turning the engine) the fan stop ...........It's ok or not.
taffy
Re: It's ok or not. my xantia
Unread post by taffy »
hi there
have you checked your lhm fluid level is correct?
engine oi land water levels correct?
as this can fire on the stop light
check these first :)
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
Xaccers
x 185
Unread post by Xaccers »
It sounds like the Bitron is playing up as both the stop and overheat lights are coming on, but the temperature is low.
The brown plug goes all the way to the Bitron which is tucked away somewhere under the right hand headlight as you face the car. When you disconnect the brown plug, the Bitron loses the temperature signal and so as a safety measure puts the fans on full speed.
Through corrosion and old age of the plug at the Bitron end, the Bitron gets false readings or none at all and so flashes the warning light and speeds the fans up.
If you have time to remove the headlight and perhaps even the front bumper (I'm not sure exactly where the Bitron is) then you can disconnect it and check the contacts on the plug and clean them up if not too bad.
Or just live with it.
DIY sphere tool
fox01
lhm fluid level ,engine oil and water levels is correct, i check it.
To clean Bitron plug and brown plug ,i will try
Thank you, both of you
