Hi all.
When I open the hatchback of my 2003 c5 the rainwater runs around the base of the rear Screen and straight into the boot. I have just bought the car and looking for a fix or upgrade before I start experimenting myself.
I understand this is a common problem so hoping someone has a fix.
John
2003 c5 rain water in boot opening hatch
johnnywhitevan
- New User
- x 5672
Re: 2003 c5 rain water in boot opening hatch
Are the drain channels clean?
I have heard this mentioned previously but I have a 53 C5 that I have owned for almost two years and never happen.
waynedance
- x 8
Its a design fault, I just open the hatch half way until most of the water runs off the boot.
Volvo S80 D5.........
Stempy
Mine too
Lexia ponce
Lexia ponce
Northern_Mike
They all do that. As Waynedance says, just open it halfway first..
qprdude
- x 14
And they haven't managed to improve on the design with the new X7 either! Because of the concave rear window or the boot lid design, when I open the boot fully, the water drips from the rear pointed edges into the boot. The boot lid opens completely vertical, thanks to the concave window, but surface water runs to the boot-lid edges and quite a bit of it misses the water channels . It's a PITA if you have clothes or luggage in the boot.
Rick.
2013 Citroen DS 5 D/Sport
Clogzz
- x 40
Is that an estate ?a 53 C5 that I have owned for almost two years and never happen.
The hatchback dumps water unless it's on very level ground.
lexi
- x 133
Lots of other makes do it too. Cars are made for wind tunnels and styling........not for opening when wet
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 5672
Both. It is the hatch I was referring to though.Clogzz wrote:Is that an estate ?a 53 C5 that I have owned for almost two years and never happen.
I must only open it on level ground as I have never had a problem with it.Clogzz wrote: The hatchback dumps water unless it's on very level ground.
qprdude
- x 14
I can't remember my Mk 1 dripping water from the hatch, but maybe I just never noticed it. Sometimes you notice things, then you are on the lookout for them all the time.
Rick.
- x 5672
I have looked for it after others have complained of it and opened it while washing the car and played the hose on it.
It is level where I wash the car though.
I remember when a workmate bought a brand new SAAB 900 Turbo just after they were launched and was very disappointed when the spoiler directed rainwater into the boot.
qprdude
- x 14
Steve, it must be a difficult thing to overcome, without adding all sorts of deflectors and channels. Maybe it doesn't rain as much where you are.
I wonder if it also happens with Rolls Royce's (don't expect I'll ever find out)
Rick.
- x 5672
I can assure you that we get more than our fair share of rain here.qprdude wrote:Steve, it must be a difficult thing to overcome, without adding all sorts of deflectors and channels. Maybe it doesn't rain as much where you are.![]()
I generally fire a load of crap in the boot before and after work and although the ground is almost level but not quite, I never have water getting into the boot.
As for RR and their ilk, I have absolutely no idea. Not likely to either.
jgra1
- (Donor 2021)
- x 36
Qpr Steve is in the UK Washington but you may know that already so apologies.. although not sure US one gets any less rainI can assure you that we get more than our fair share of rain here.
I open my C5 hatch quite carefully when wet.. I think Xants did this boot filling too? I could be wrong..
john
qprdude
- x 14
jgra1 wrote:Qpr Steve is in the UK Washington but you may know that already so apologies.. although not sure US one gets any less rainI can assure you that we get more than our fair share of rain here.![]()
john
Yep, I knew that John. It was kind of tongue in cheek when I said maybe it doesn't rain where you are.
Rick.
