MK1 XANT window reg
x 94
MK1 XANT window reg
Unread post by citronut »
a customer of mine has an L reg Xant 1.9TD hatch,
he purchased a new repair piece/block/clip from ebay
http://tinyurl.com/obx5u3b" onclick="window.open(this.href);return false;
on checking/trying to fit this block,
although the listing states it fits 1990 – 2002 cars, there is no way i can see it fitting the regulator from my customers car,
as this block requires two cable end nipples one coming from each end/direction,
as does this type
http://tinyurl.com/ph6fx5g" onclick="window.open(this.href);return false;
the regulator i am trying to sort has a single straight/run of cable with two nipple/crimps no more that 3/8'ths of an inch apart from each other,
these crimps are what the block attaches over and onto the cable,
on a MK2 regulator the block is attached on two separate cable end nipples, as im sure the new block requires
any input gratefully received
Regards, malcolm.
