Hi
Can any of you learned guys help with a fault that has developed on my 2008 dispatch 2.0 hdi. The starter motor will not turn over the engine when using the ignition key, nothing there at all. My initial thought were the starter motor had packed in but if I disconnect the auxiliary wire to the starter motor (the thinnest wire) and then run a wire from the starter motor solenoid terminal straight to the positive terminal on the battery with the ignition turned on. The starter motor starts the engine and the van will run as normal.
I would appear that I am not getting a 12v feed down the starter motor solenoid feed when trying to start on the ignition key
Are there any starting relays fuses etc that I could check and if so any idea where they are fitted
The fact that I can start the van with a direct feed from the battery proves to me that the starter motor and immobiliser are working ok, but I may be wrong
Engtech
Citroen dispatch starter motor fault
- x 1240
Re: Citroën dispatch starter motor fault
The first thing to check is the ignition switch, if you have power from there a wiring fault is most probable, or you could fit a push button starter on the dashboard - like my 1954 Hillman Minx
Kal13
Re: Citroen dispatch starter motor fault
Sorry wrong post
- x 1746
If the fault is the same as Engtech describes, then Peter is right: the fault is with the IGN switch.
The starter solenoid (which triggers the main starter motor windings) itself takes around 25A, and not all IGN switches survive this, long term.
Two solutions, without fitting a new IGN switch (itself expensive and not an easy job):
- install a press-to-start switch between batt+ and the starter motor small connection, as Peter suggests;
- install a relay (a 40 or 80A one preferred) in the same wire; IGN switch turns on relay, relay brings batt+ to s/motor.
Good few folk have done the latter. It gives the IGN sw an easy life.
Dubris
I had a similar problem on my 2004 Citroen Dispatch so I wired a 20 amp retractive switch with 4mm2 cable between battery and solenoid, when I operate the new switch now the solenoid just clicks, is it time for a new solenoid ?
