2.0 TCT engine removal
xantos
x 10
Unread post by xantos »
I'm about to remove the engine from my Xantia Activa.
Anyone has some experience with renewing the engine? I will change: belts, water pump, tensioner, head gasket, valve gaskets, piston rings and of course give it a good clean. Anything else that I should do since the engine is out?
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet :-D )
C4 Exclusive 2.0 HDi (gear shifting b****!)
