Diagnostic hardware/software...Lexia, PP2000.....n00b
jotto
Unread post by jotto »
I did a search and didnt really find what I was looking for but I'm pretty sure this question has been asked many times so sorry to go over it again.
As a new convert to Citroen, What exactly do I need to buy to plug in to the car, read any codes,erase faults, check and test components etc?
I have a laptop that I use with our ford Galaxy, the software is free and the lead was about £6. Plug it in, read the codes, erase codes...log live data etc. All fairly simple.
Reading through some of the lexia posts on here it seems to be a little more complicated for the Citroen?
From what I have read so far, I need to get something like this?
http://www.ebay.co.uk/itm/Lexia-3-Diagn ... 35cfcd42c2
Also, the laptop to run it is generally better to run with XP pro? Any ideas if the software will run inside a virtual box enviroment?
What are the different bits of the kit? I see mentions of Lexia, PP2000 and also Diagbox.
Apologies once again if this makes you all throw your arms up saying not another lexia thread! :-D
Xsara Picasso 2.0 HDi ( 53 plate )
jgra1
(Donor 2021)
x 36
Re: Diagnostic hardware/software...Lexia, PP2000.....n00b
Unread post by jgra1 »
hi Jot
I am a newbie re diagnostics but
yes to the interface, I didn't click the link but pay maybe 70 £ for it and the software etc
but..
I think you need to download software from a link on here instead,.. it takes a while and can be a little problematic to install - depending on your IT skills. think disc images and mapped drives..
I will be corrected but my understanding is Diagbox is modern Peugeot / Citroen software for recent cars... but incorporates lexia (older cits) and PP2000 (older pugs) - these software run from within diagbox,
I managed to run it in a netbook running windows 7, after a few hiccups..
may run easier in XP but fine on 7
don't accept any updates that you will surely be asked for when installing and running
also, once all done, you need to remove and insert USB just around the time you select Lexia software, otherwise communication goes pete tong
essentially, you need the software, the interface, a USB cable between them, and the main lead onto the car ODB port..
others know way much more ;)
John
x 94
Unread post by citronut »
i dont know if its still available but there was a DIS-LEXIA for sale on here, link below
http://www.frenchcarforum.co.uk/forum/v ... =7&t=47148" onclick="window.open(this.href);return false;
Regards, malcolm.
Bandit12
x 12
Unread post by Bandit12 »
Hi Jotto
I'm new to this Lexia stuff too. this is where I got mine from
http://www.ukpolboy.comoj.com/1_8_Lexia ... cable.html" onclick="window.open(this.href);return false;
It comes with everything needed (except instructions!) I emailed the seller and he guided me through the process. XP is recommended but I'm aware of others who use windows 7 and 'trick' the laptop inot thinking its XP.
It is a quirky program but then citroens are quirky cars :-)
good luck with it mate
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone) :(
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade) 8-)
x 3296
It will work on Windows 7, but (if you want to cover most cars, i.e. more than a few years old ) it will need to be a 32bit version. While it will work on 64bit, very few cars can handle 64bit communication.
taffy
Unread post by taffy »
yeah i couldnt for love or money get 64bit to work..32bit or xp..im running xp and its spotless really ;)
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
rosak
Unread post by rosak »
I'm running Diagbox 7.x with Chinese device for around 50 quid on Windows 7 x64 with no tricks, no issues.
For those who are not familiar with IT- the way 32bit program (Diagbox) communicates with 64bit CPU has nothing to do with USB- communication with car.
If you don't need to change anything in your vehicle's ECUs, just read/clear faults and to have an access to live data from your smartphone, use OBD2 Bluetooth device like ELM327 for around 6 pounds.
jotto
rosak wrote:I'm running Diagbox 7.x with Chinese device for around 50 quid on Windows 7 x64 with no tricks, no issues.
Where did you get your device and does the ELM327 come with it's own software?
I have a usb OBD2 Lead that I use with vagcom software.....I wonder if it would be compatible with some software that I could download?
rosak
Sorry I've made a mistake, I paid 73 for Lexia device.
Elm327 doesn't have any own software, it's just OBD2 reader, works with anything. Ie. I use Torque for Android but there are a lot more. Check YouTube to see what it can do.
Jodyone
x 3
Unread post by Jodyone »
FWIW, I tried to get my Lexia working on an old windows laptop, and struggled... it installed in the end, but never worked properly, except for one evening back in September..! After which I updated it and everything fell apart again. I'm not very Windows-experienced though so it may have been partly my failing. Recently I installed it in fresh XP under emulation, in Parallels on a recent Macbook Pro, and it's worked fine ever since- to my surprise! I had trouble with Diagbox (it never launched Lexia successfully) so I didn't bother this time. I went with the "quit while you're ahead" approach and won't try to update it.
2006 C6 Exclusive, 2.7 HDi - Big Ron. Long gone!!
x 1496
Got a reason to buy one now - Sister's Xsara's HDi has gone into limp. Jim at Easy diagnostics points out his is Rev C and others might not be - does anyone know if Polboy's offering is the latest, and will cover up to date cars?
vborovic
Locked user account
x 40
Unread post by vborovic »
Just to ask, anyone knows whether this seller is credible, and if the package he sells will work for my C5 X7? Out of all the ads on ebay.co.uk, this one seems the latest piece of software and the best feedback ... http://www.ebay.co.uk/itm/LEXIA-3-CITRO ... 3389a5f3c2" onclick="window.open(this.href);return false; ... also, what's the reason to use (and pay extra) for the S1279 extender (read: do I need it), the item is here: http://www.ebay.co.uk/itm/CITROEN-PEUGE ... 3389a5f53b" onclick="window.open(this.href);return false; ?
taffy
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1281257524" onclick="window.open(this.href);return false;
i bought this one recently and all works well
