scuttle sealant
- froggy
- Donor 2023
- My Cars: S2 Xantia Forte 185435.
Peugeot 306 Meridian, the boss. - x 2
scuttle sealant
Hi, I need to reseal the windscreen scuttle on my series1 Xantia , anyone know the name of the sealant ? many thanks Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
Re: scuttle sealant
Can't tell you what the original sealant was or if it was silicone based, if it was you must use silicone again.
In the event the surfaces are not contaminated with it the best sealant by far is called CT1, it has many uses and can even be applied to wet surfaces and underwater. A very useful solvent called multi solve is available alongside too and can be used to remove any unwanted sealant after application.
A similar product from Soudal is available through Lawsons and is a bit cheaper.
Cheers
Paul
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
