2cv owner in need of some advice
rosemary
Unread post by rosemary »
Hi All My 1984 2cv6 has a cv joint knock. Do I have to buy a whole driveshaft if not how do I know which part is defective. I am confused as I see both halves for sale separately. If I have posted this in the wrong place I am sorry but I am new to this.
Thanks for your help.
Northern_Mike
Re: 2cv owner in need of some advice
I'd imagine you only need the outer part, ECAS have them for about £49 reconditioned. I've never had an inner part wear out on a CV jointed 2CV.
rosemary
Thanks for that.
x 94
Unread post by citronut »
hi and welcome
you might well find its only lost all its grease through a split CV boot/gaiter, in this case it would just require the joint removing, cleaning out, new grease and CV boot fitting
were are you located
Regards, malcolm.
rosemary
Hi Malcolm I am near Dumfries
x 94
rosemary wrote:Hi Malcolm I am near Dumfries
ok
so just a teensie bit to far for me to check it for you #-o :wink: , as in at the bottom end of the A21 on the south coast
Regards, malcolm.
