Changed the MAF sensor today! Disconnected the battery to do so and left it for about an hour. Also added some snazzy engine cover clips so it now stay on! Hooray!
Then I went to start the car. It wont start and the Electronic immobiliser ignition light is lit. Have only tested it with Remote key so far, have a 2nd key I havent tried!
Help, how can I make my car realise that I am its owner????
Immobiliser issue! HELP!
cpikey316_
Light bluey 2002 C5 LX
jgra1
- (Donor 2021)
- x 37
Re: Immobiliser issue! HELP!
happened to me twice.. the fuse / relay board in the engine has a bad contact.. if all else fails, bash it a bit
good luck
good luck
cpikey316_
Is the fuse/relay board the black box next to the battery?jgra1 wrote:happened to me twice.. the fuse / relay board in the engine has a bad contact.. if all else fails, bash it a bit
good luck
Is there a better way to try to fix this problem, not that I am ad-versed to bashing, but generally like to try something a bit less 'pikey' first.
*UPDATE*
A big bash seemed to sort it out! Thank you Jgra1!
taffy
haha always the same with these cars...a good clout in the right place lmao!
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
jgra1
- (Donor 2021)
- x 37
Same problem left me carless for a week in 2012..
until i accidentally knocked that area..
I will one day take mine apart and find the bad contact but when its nicer out
