Hello!!
I have a citroen jumpy 2003 2.0HDI RHZ 110hp. One morning some days ago the car didnt want to start.
First thing i did was to diagnose it with peugeot planet but the ecu does not respond. All the modules(extra heater, bsi and alarm gives the fault code that the engine ecu does not respond).
Is there some relay or fuse for the ecu? I have a car guard alarm to the car with immo, maybe this is connected to cut power to ecu.
What does the pro:s in here think??
Regards
Starting problem/ECU-problem jumpy hdi 2003.
- x 5662
Re: Starting problem/ECU-problem jumpy hdi 2003.
Can you confirm the make/model - I presume a C5 but it could be several others.
Northern_Mike
It's a Jumpy.
Known as a Dispatch here...
- x 5662
Thought that was a symptomNorthern_Mike wrote:It's a Jumpy.
Northern_Mike
It probably is!
qprdude
- x 14
Me too.myglaren wrote:Thought that was a symptomNorthern_Mike wrote:It's a Jumpy.
Thought the dispatch was a van.
Rick.
2013 Citroen DS 5 D/Sport
anson
- New User
yes its a dispatch, in sweden we call them jumpy
I tried to switch ecu, key, alarmbox, double-relay but same problem, its quiet in the engine bay when key is turned on =(
I get 12v to the ecu when i put ignition on
jgra1
- (Donor 2021)
- x 36
have a gentle hit of the engine fusebox area Anson? while ignition on. you may get lucky..
John
John
