Dispatch not starting
g7tzz
Unread post by g7tzz »
Hi all, I'm new to the forum so hope I'm posting in the right area. I've just bought myself a 2000 Dispatch 1.9D none starter. After charging the battery it turns over ok but won't start. The lights come on on the dash and the immobiliser light goes off, the glow plug relay is working but that's about it. There is fuel at the pump but not the injectors. One thing I noticed while under the bonnet is the glow plug relay clicks on and off when the ignition is off every few seconds.
Any help would be appreciated. Thanks Jon.
taffy
Re: Dispatch not starting
Unread post by taffy »
could be stop solinoid if ur pump has one maybe?
is it a 1.9 non turbo?
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
g7tzz
Yes it's the 1.9 non turbo, I presumed it could be stop solenoid but I couldn't find one, there are 2 4pin connectors on the pump but I can't see where they go.
x 94
Unread post by citronut »
maybe the stop solenoid is hidden inside the immobiliser armour on the back of the pump,
or it might be the immobiliser its self
were are you located
Regards, malcolm.
g7tzz
I'm in Geddington, Northamptonshire. Is there any diagrams or pictures available for the pump as I can't seem to find much information about this engine. Is there a way of testing the immobilizer/stop solenoid.
Thanks Jon.
wotwot
(Donor 2021)
x 4
Unread post by wotwot »
not really much to go wrong on these engines.
Have you cracked the pipes that go to the injectors and turn the engine over, small amount of fuel means either pump solonoid or as I have seen happen the AA man managed to damage the pump whilst trying to bleed the system.
If it is the stop solonoid it is possible to de armour the pump although it is a one time thing ( you wont have an immobiliser ).
When you got the vehicle did you know what happened to it.
There are some good photos on here of the bosch pump, I assume there will be some of the epic lucas as well. If I find them in my previous post I'll tag you in them.
found the link to the post I made on this problem, there maybe a few things in it that will help.
http://www.frenchcarforum.co.uk/forum/v ... =3&t=36220" onclick="window.open(this.href);return false;
x 94
thry is loads on here and with picy's, we need to enlist the help of Stevie baby ( mygleran ),
he who has the knack of
threads out
Regards, malcolm.
wotwot
(Donor 2021)
x 4
trouble is citronut ferrets cant hold spanners :rofl2:
g7tzz
I bought the van as a non runner, the guy who owned it said it just didn't start one day. There is no fuel at the injectors.
I presume the stop solenoid is under the pump or between the pump and engine as I cant see it. I don't mind loosing the immobiliser
if I need to. Does it have to come off or can it be bypassed.
wotwot
(Donor 2021)
x 4
It has to come off not a difficult job but dont go gung ho at it.
there should be a topic on the immobiliser somewhere try a search for it.
x 94
does this wagon have the key pad imobaliser
the stop solenoid is on the end of the pump just above were the injector pipes connect,
but if it has an immobiliser it will be under/inside the immobiliser armour,
i de/ armoured/immobilised my old XANT in situe, time consuming/fiddly, but doable,
there are some tricky and hidden shear bolts you will need to get at, which on mine involved cutting ( with an angel grinder and dremal type tool with a cutting discs ) chunks of the armour away just to get at some of them,
to de/ immobilise it you have to remove it with the armouring, then connect a switched live straight to the stop solenoid,
you pick up the switched live feed from one of the square plug connectors attached to the bracket on the pump just below were the throtle cable inner seats
Regards, malcolm.
g7tzz
Ok thanks for the replies, I'll get the hammers and grinder out then.lol I'll search for immobilizer before I start, I don't want to strip it all down to find there is no feed to the immobilizer. I have an ignition live on one of the connectors but I don't know what the other pins do.
x 5666
The only thing I have located up to now is Jim's stripdown & refurbish blog/howto.
x 94
g7tzz wrote: I have an ignition live on one of the connectors but I don't know what the other pins do.
dont worry about the other pins, i think if memory serves it was an ignition live in the square black plug block, then the rest in that block are redundant
Regards, malcolm.
x 94
myglaren wrote:The only thing I have located up to now is Jim's stripdown & refurbish blog/howto.
i just had a quick flick through that link Stevie and could not see picy's of the imobaliser fixings or removed,
can you try a different feret :rofl2: :-D :wink:
Regards, malcolm.
