Xantia Lhm pump leak
kilianmanning
Unread post by kilianmanning »
Hi guys. :-)
First time poster here.
I have a 96 xantia 1.9td hatch with a leaking lhm pump.
The leak is coming from the bottom bolt/union on the lhm pump. An o ring is fitted on the union but my car keeps shredding the o ring after a few days driving. :(
Would anybody have any ideas?
I'll put up pictures later if needed.
x 94
Re: Xantia Lhm pump leak
Unread post by citronut »
hi and welcome
are you fitting O rings bought from citroen, or just stranded O rings,
if the later try the proper citroen O rings
here is part No.'s and dimensions of the two different sizes in one pump
4026 87
HYDRAULIC OIL O-RING SEAL
DIAM 16-TO 1,9
4026 88
DIAM 19-TO 2,4
and price and part No.
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000402687 HYD OIL O-RING 1.35 GBP 1.62 GBP 1.62 GBP
0000402688 HYD OIL O-RING 1.15 GBP 1.38 GBP 1.38 GBP
Regards, malcolm.
VertVega
x 13
Unread post by VertVega »
O-ring must be type NBR (Nitrile butadiene rubber) which is LHM compatible.
Try the ones given in citronut's message.
kilianmanning
OK thanks guys.
I am just using standard o rings at the moment.
I will get the proper o rings from Citroen & see does that solve the problem.
Does anybody know which of those two sizes of o ring I need?
VertVega
x 13
kilianmanning wrote:The leak is coming from the bottom bolt/union on the lhm pump.
Then it must be the size --- DIAM 19-TO 2,4
I would suggest you to buy both sizes (DIAM 19 and 16) as spare parts.
They don't cost a fortune and you can't find them easily.
Total amount of O-rings of both sizes in Hydr.pump:
- 2 pcs O-rings 19 x 2.4
- 6 pcs O-rings 16 x 1.9
and for a complete overhaul of pump these are also needed:
- 1 O-ring 44 x 2.3
- 1 O-ring 36 x 2.5
kilianmanning
- 1 O-ring 44 x 2.3
- 1 O-ring 36 x 2.5
Ok thank you, I'll get a packet of each
x 94
- 1 O-ring 44 x 2.3
- 1 O-ring 36 x 2.5
this is the only other pump seal shown on service citroen, and i cant find a seal kit
4026 86
44,2T3
- INJECTION XU5JP
44,2T3
- INJECTION XU7JP
44,2T3
- INJECTION XU7JB
44,2T3
- INJECTION XU7JP4
and here is price and part No.,
it shows 1 required
0000402686 HYD OIL O-RING 2.55 GBP 3.06 GBP 3.06 GBP
Regards, malcolm.
citroyiannis
Unread post by citroyiannis »
kilianmanning wrote:The leak is coming from the bottom bolt/union on the lhm pump. An o ring is fitted on the union
Hi citroenians,
Its all right with all those O-rings and their part numbers. But what about the O-ring inside the HP front union which is next to the pulley? The official Citroen site dose not give any part number for it neither a part!
citronut wrote:and for a complete overhaul of pump these are also needed:
- 1 O-ring 44 x 2.3
- 1 O-ring 36 x 2.5
This one: 44 x 2.3 (Citroen spec.:44,2T3) has the part No: 4026 86, and I suppose is for the "bottom HP union" which killianmanning ask for.
Whats the part number of the other one (36 x 2.5) you mention here? Is it for the front union? Where can we find some of this?
I need some for HP pumps: 4007 T9 (XU10J4R/XU10J2TE) and 4007 T4 (XU7JP4).
Regards,
Yiannis
BX 1.6 TRS 8V '89 Grey
Xantia 2.0i 16V, '00 auto, Hydractive, White (dove)
Xantia 2.0i 16V, '98 auto, Non Hydractive, White
C3 1.4 HDI, '05 sensodrive, Lucia Blue
Xantia 2.0i 8V, '99 TURBO Activa, Silver Grey (Neil)
Xantia 2.0i 8V, '99 TURBO Activa, Silver Grey (Heather)
x 94
Hi citroenians,
- 1 O-ring 44 x 2.3
- 1 O-ring 36 x 2.5
Regards,
Yiannis
Regards, malcolm.
x 94
no this 44mm O ring fits between the twi pump body half shells,
the leak killianmanning talks about, i belive will be repaired by one of these two O rings, not sure which one 16mm or the 19mm
4026 87
DIAM 16-TO 1,9
4026 88
DIAM 19-TO 2,4
citroyiannis wrote: Whats the part number of the other one (36 x 2.5) you mention here? Is it for the front union? Where can we find some of this?
Regards,
Yiannis
i cant find the part or No. for the 36mm O ring now,
but service citroen does not show rhe front end seal/O ring,
i remember having a conversation with Martin at Pleiades regarding the front end seal,
he said the OE seal is not available from citroen, and when he reconditions these pumps, he makes/has made a new metal front plate which uses a seal/O ring he source's from a different supplier,
were as the orihinal face plate is plastic which cracks
Regards, malcolm.
VertVega
x 13
- 1 O-ring 44 x 2.3
- 1 O-ring 36 x 2.5
citroyiannis, the text "and for a complete overhaul of pump these are also needed:" was originally sent by me. I got this information from another site and saved it in my computer but I don't remember the original source.
As citronut also written, probably the leaking seal type is either #4 (diam 16) or #5 (diam 19) in kilianmanning's Xantia.
I used to have a Xantia 2.0i 16V and below pic is same type as in my car.
The unlisted O-ring seal is number 6. It is not included in the citroen diagrams. I think it is an ordinary seal (not NBR) because there is a bearing there and I guess it does not have any contact with LHM. You don't necessarily need to change it if it is in good condition.
kilianmanning
I have 5 of 402688 & 402687 ordered. :)
Thanks for all the help guys hopefully i'll be motoring again soon
x 94
VertVega wrote: The unlisted O-ring seal is number 6. It is not included in the citroen diagrams. I think it is an ordinary seal (not NBR) because there is a bearing there and I guess it does not have any contact with LHM. You don't necessarily need to change it if it is in good condition.
Vert
i would say the front seal must have contact with citro blood, as when the pump leaks from the front end it is the green blood weeps from there
Regards, malcolm.
aneesh84
x 29
Unread post by aneesh84 »
If I want to just change seals 4 and 5, is it a pump out job? Some of the seals at the bottom are leaking. The leak isnt too big but everytime i put my fingers there i find it oily and i am worried it might damage the alternator.
If its a pump out job, then i might as well replace all of them as a preventive maintenance.
Xantia Estate 1999 2.0 HDI 110
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
Renanek9
x 4
Unread post by Renanek9 »
VertVega wrote: 05 Jan 2014, 18:21
- 1 O-ring 44 x 2.3
- 1 O-ring 36 x 2.5
Hello Guys.. Sorry for digging up this thread
Would the "unlisted O-ring seal" be this one?
I'm having trouble finding this one. It NEVER appears on any overhaul diagrams for this pump.
What I have (and is found everywhere) is:
6x 16mm diameter O-rings, thickness1.9mm. REF. 402687
2x 19mm diameter O-rings, thickness 2.4mm. REF. 402688
1x 44.2mm diameter O-rings, thickness 3mm. REF. 402686
1x O-ring 36.17 x 41.41 x 2.62 - NBR90
1x A double lip seal type SPI gasket Double lips OAS - 15 x 24 x 7 NBR
But nowhere can I find this one from my photos. Can you help me?
By the way, it looks A LOT like the spheres retaining gaskets! lol
Xantia Ph 2 Activa V6 - 7681CJ / VH000121
