okay my dad today was trying to blank my egr valve off we and couldnt for the life of us find it!!!!
its a 2l hdi 01 picasso
many thanks
Kate
EGR Valve Picasso?
taffy
Re: EGR Valve Picasso?
its down the back of the engine...where the exhaust is then look up to under the intake manifold
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
katie86
found it thank you
but how are you suppose to access it and blank it off! without taking the engine off!
taffy
good question...lol aint done mine yet but im sure someone will be along shortly..
Northern_Mike
You disconnect the "other" end of the EGR assembly towards the passenger side. 2 bolts. Slip the blanking plate in there, tighten up again
Be warned that if it's a Siemens injection engine (it'll say on the fuel rail or pump) it's likely to get annoyed if you do this, throw up an engine light and go into limp home mode.
katie86
thanks for the replies guy
but still cant see were we fit this, think we will leave it
fitted new maf sensor that seems to be working now
still got engine codes
p0110 and p0120
dam
p0110 and p0120
dam
Northern_Mike
When it stops lashing down, I'll take a picture of where it goes on the Berlingo with the same engine and post a link to it..
katie86
many thanks mike , the weather is stinking!
seems we need a new radiator, as it does not seem to be leaking but has corroded lots , also found a few fuses missing in the fuse box under the bonnet, now i have a new warning light code for the tempreture control , so looking for a new radiator, thermostat etc.....
need to do an earth mod i believe off the maf sensor awaiting on multimeter ,
replaced maf sensor and it seems to be working now via android app torque
- x 3296
It is not unusual to have a few 'missing' fuses. These would either be for equipment in a car with higher spec, or, as some parts (such as fuse boxes) are used in different models of vehicle, for equipment not fitted to a given model.
