Xantia wishbone bushes.
x 1485
Finally going to have to do the NS wishbone bush on the Xantia - noticed yesterday when torquing the wheel bolts up after doing the drop link, that there is visible play in the pin now :lol: I know there are stories of short lived bushes - so what recommendations on what to fit, or is it just getting the alignment right that's more important? Just fir the rear bush, or is it worth struggling with the front one as well?
Going to need a bit of money spending on it in the next few months...new front tyres waiting to go on, just fitted drop links, new exhaust cat-back pipe required, front discs and pads, wishbone bush, needs a new windscreen and torque reaction link as well really :roll:
x 94
Re: Xantia wishbone bushes
Unread post by citronut »
i would preferably go to GSF for the bushes, and steer well clear of that E company, especially for the likes of bushes
Regards, malcolm.
c.morewood
x 55
Unread post by c.morewood »
Fit the best you can afford.. GSF ones are good BUT you have to get the alignment angle correct on the rears and make sure the 2 bolts are done up nice and tight.. it might even be worth replacing them as they can get very rusty/worn just below their heads.. I haven't had any problems with the front bushes.
Good luck,
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
lankytim
Unread post by lankytim »
When I was swapping a CV joint I noticed that there seems to be quite a bit of movement in the wishbone bushes, especially the rear one. Is it easy to renew them or should I buy complete wishbones? Does anybody know the best/cheapest place to get them?
x 94
Re: Xantia wishbone bushes.
depends how long you want them to last to how cheap you purchase them for really,
RichardW has a thread just started
http://www.frenchcarforum.co.uk/forum/v ... =3&t=47063" onclick="window.open(this.href);return false;
Regards, malcolm.
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
i looked at the option of new arms, there is a guy on ebay that had 1 NOS arm, iirc was £30+postage, and another guy who had one that cross referenced from a 106! similar money but both the same, bushes vary from a tenner upto 25 a pop, and for the p bushes they are quite easy a job for the usual DIY mechanic with a bench vice! i managed to do both of mine, one p bush was shot and span off the inner sleeve leaving just the sleeve on the arm to cut and tap off, the other was just a spin it round with a bar whilst the arm was in the vice, then tap the inner sleeve off, fitting was line it up as per the old one and tap it on, the front ones were a bit tougher but once the edges had been disturbed it tapped out,
i will confess i went the cheap bush option but on the basis that they are the same bushes i have had form my local factors before, and the same brand as the ball joints i had, qep iirc.
'58 C2 Code
'58 partner teepee outdoor
taffy
Unread post by taffy »
i bought a cheep set on ebay and they went under a week...i bought Lemförder ones to replace and there very good quality
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
taffy
but that e company sell Lemförder...thats where i went and they were v close to origionals
http://www.eurocarparts.com/suspension-bushes" onclick="window.open(this.href);return false;
lankytim
Thanks for the info guys, Are Euro car parts really that bad?
taffy
i useually shop between them and gsf..quality and price issues with both ive found
lankytim
Euro do Lemforder for the front and Febi for the rears.
Timmo
(Donor 2022)
x 168
heres one of the wishbones complete, will try and find the other, (was also the same side mind!)
http://www.ebay.co.uk/itm/DRIVERS-SIDE- ... 43b77da884" onclick="window.open(this.href);return false;
'58 C2 Code
x 94
lankytim wrote:Thanks for the info guys, Are Euro car parts really that bad?
after paying out just over the £100 quid each for a pair of Volvo V70 front arms ( heavy cast alloy ) and the bush's literally falling apart within the year,
then a Bosch boxed Lambda sensor not even firing up on the return MOT emissions test,
both of which were for customers cars
it tends to leave a nasty taste in the mouth,
Regards, malcolm.
