Went out to use the Xantia for the first time in quiet a few days and the battery was a bit run down, enough to prevent me from starting the car. This could be a side issue from the window problem, but the window problem could be the cause of the drain on the battery.
Anyway, while I was sorting out getting the car started I noticed that the front window switches were illuminated even when the ignition was off. Now while I would have thought that the bulbs in the switches (and I believe from the wiring diagram that they are LEDs) wouldn’t have much impact on the battery over several days, they are not supposed to be on when the ignition is off.
Checked the operation of the front windows and they go up and down without the ignition on which certainly isn’t right.
First thought was that the window power relay had failed on - pulled what I think is the window relay (middle one of the 3 green relays just above driver’s feet) no change.
Assuming I had pulled the right relay, I then pulled fuse F27 (permanent 12v feed to windows switched by relay) window switch lights go out windows don’t work.
Looking at the wiring diagram in the Haynes manual, shows that the permanent live 12v feed from fuse F27 goes to components 6035 and 6038 which are the window motors in the doors before the window power relay. The supply that is switched by on by the window power relay when the ignition is switched on (Line B27 to relay, Line 600 leaving relay) also goes to the window motors in the doors.
Not had my meter on the car yet but I am assuming that somewhere there is a short between the unswitched supply B27 and the 600 circuit which should be switched by the relay but I suspect is now permanently live.
My plan is to start looking for the fault in places where the two circuits B27 and 600 coexist, ie at the window motors and in the loom where the wires might be running together, at the relay and into the doors.
I could be in for a long hunt.
