Heater hose
KennyW
x 163
Heater hose
Unread post by KennyW »
H All,
I've got a pesky leak from a heater hose No 11 Citroen service (part No 6466 27), this part s NFP
See attached picture.
Simple question what size is it?
C3 1.4 petrol (SWMBO)
x 1238
Re: Heater hose
Unread post by Peter.N. »
Probably about 5/8" - 3/4" I would think. Can't you measure it?
KennyW
x 163
Re: Heater hose
Thanks Peter,
I am going to do that but I was hoping someone may have had to replace/find replacement and had the size.I want to be prepared before remove and refitting since I have to empty the coolant. So going to replace coolant with new stuff.
Kenny
x 1238
Re: Heater hose
Measure the outside diameter, I would think the wall thickness would be about 5mm, can you see the end to measure it? Most small hoses are about the same size, used to be 1/2" but I think its nearer to 3/4" now.
KennyW
x 163
Re: Heater hose
Peter,
I can reach it and measure same but that will be for another Year :)
Kenny
Clogzz
x 40
Re: Heater hose
Unread post by Clogzz »
Hi Kenny,
The internal diameter is 3/4" from what I remember.
Working on the heater hoses is very tricky because the plastic connector to the matrix is brittle.
Sticking a piece of gaffer tape will keep the coolant in for now, and driving with the coolant cap loose will prevent pressurisation.
I never tighten coolant caps, and no problems here even when it’s 30 degrees.
Happy New Year. Image
2002 C5 2.0i AL4 239,000 km 76372389
taffy
Re: Heater hose
Unread post by taffy »
one of my xants 1.9td broke its aux belt and damages the bottom hose...i was stuck and needed to get to work so i went to halfords and bought an exhaust repair kit and wrapped the hose up...it lasted till i broke the car..but to the point as a precausion i took off the coolant cap and continuied to drive...infact i diddnt put it bk on and i done thousands of miles like that..just astonished it diddnt spew all the water out or evaporated(well i did top itup every now and then but it wasnt more than a mug of tea!
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
KennyW
x 163
Re: Heater hose
Thanks for the replies Clogzz and Taffy,
At the moment with the amount of rain falling there is no need to top up :-D 3/4 " ideal was think of using a new plastic connector.
Kenny
