chaps, just driven from oxford to Kent, got within 3 miles of home and decided to shop.. back to car and immobilser fault coming up when I tried to restart..
have only one key for car, although another one 10 miles away in a barn, I hope.,.
tried locking / unlocking car. took key apart and tried to get another battery but none for sale (key is non fob style but does have a battery in it - aftermarket)
did a (fast) soft reset, nothing..
have lexia here for as long as laptop battery lasts,.. anything I can try? - or should I try spare (service) key
or AA?
John, thanks for any /quick/ help
urgent help . immobiliser fault
- My Cars: citroen C5 estate 58 plate.........2.0 hdi
Re: urgent help . immobiliser fault
is it turning over ok?? I have a C5 which had a dodgy battery and a few times I got "anti theft device faulty" in the display.....I put a new battery on it and it cured it?? best I can offer........good luck
C5 X7
Any battery in the key won't be relevant to an immobiliser fault as the immobiliser uses an RFID style tag which is powered by the induction loop in the pick-up antenna on the ignition barrel - eg no batteries required.jgra1 wrote:chaps, just driven from oxford to Kent, got within 3 miles of home and decided to shop.. back to car and immobilser fault coming up when I tried to restart..
Have you checked the car battery voltage ? As deano says low voltage from a failing battery can bring up all kinds of weird faults on a C5 including immobiliser failure, so the most likely cause is your battery has died.did a (fast) soft reset, nothing..
or AA?
If you don't have a volt meter to check the battery voltage you could try using the Lexia to get a battery voltage reading - if you can establish communication with the engine ECU you should get a battery voltage reading from there.
You could also use the Lexia to read the fault codes from the BSI which should have a code explaining why the immobiliser failed - for example "unable to read key identity" or similar...
But definitely check battery voltage first and get a jump start if necessary - if it starts ok with a jump start you know its a battery problem...
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
thanks all
um
'Any battery in the key won't be relevant to an immobiliser fault as the immobiliser uses an RFID style tag which is powered by the induction loop in the pick-up antenna on the ignition barrel - eg no batteries required.'
Simon, wonder what the battery does then? just curious? no buttons.. just a circuit board and a 3v battery...
well.. went and got spare key, the service key.. was greeted by the whole roof including timbers missing from the storage barn,.. I had to smile at that.,. been an interesting xmas already... will deal with that tomorrow..
spare key the same... bashed my hand on the fusebox area as I was beyond caring.,,
yep.. that was that got home fine.. albeit a few hours later...
realised I had the same problem a year ago.. something gets loose in there and the immob warning comes up..
so, thanks for all pointers.. if in doubt, and the lexia wont help, hit areas of electrickery and you culd get lucky
um
