Xantia MK2 - Worn steering ram bushes
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
I have a Xantia MK2 with a power steering. The steering ram bushes are worn .When turning the steering wheel rapidly left/right a knocking is heard. I logged to Citroen service and could only find the steering ram ( part # 4005.A2) but not the bushes. Can the bushes be bought separately ( I need the Citroen part number ) or they are integral part of the steering ram ?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 94
Re: Xantia MK2 - Worn steering ram bushes
Unread post by citronut »
here are part No.'s and dimensions of the bush's for a BX
the bush's at both ends of a ram are the same size, so the first No. is for one type/age of ram and the second for later ram,
i would think then the later one will almost certainly fit a Xant ram
4059 06
STEERING CYLINDER ARTICULATION
DIAM 20
- UNTIL RPO 03614
4059 07
DIAM 22
- SINCE RPO 03615
here is price and part No.'s
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000405906 ARTICULATION 5.61 GBP 6.73 GBP 6.73 GBP
0000405907 ARTICULATION 6.73 GBP 8.08 GBP 8.08 GBP
Regards, malcolm.
lancia58
(Donor 2022)
x 8
Hi Malcolm
Thanks for your help. Do you also know the part number of the plastic bag that covers the ram ?
Zohar
VertVega
x 13
Unread post by VertVega »
It was also gone in mine and never got a replacement. It looks like a "shower cap" :) but I can't see the part number in service pages :?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Try an extra large Durex.
x 94
Re:
addo wrote:Try an extra large Durex.
trouble with that Adam the steering will be coming and going all over the place :yikes: :rofl2: :-D :roll: :wink:
and it might go all stiff on you :shock: :twisted: :-D :wink:
Regards, malcolm.
lancia58
(Donor 2022)
x 8
Hi
It turned out that the bushe's outer diameter is 24mm, I used a none Citroen part that was handy at the garage. I tried to find out what is the Citroen ref number for a bush with outer diameter of 24mm could not find. Anyone knows the number ?
Zohar
x 94
can you send me the last 8 digits of your chassis/VIN No.,
although i doubt it will help as service citroen do not show those bush's as a separate part for any of the Xantia's MK1 or 2
Regards, malcolm.
lancia58
(Donor 2022)
x 8
The VIN number is VF7**************[VIN obfuscated, can be read by forum staff]
Zohar
KennyW
x 165
Unread post by KennyW »
Zohar,
Are you talking about the bush on the end of the ram which bolts onto the rack. If so there is nothing listed,but the number are as follows for the complete ram:
4005 A2 for all
except
Turbo injection XU10J2TE,Injection ES9J4,TDXUD11BTE and TD DW10ATED which is
4011 47
I'm sure Malcolm will correct this if they are wrong.
Kenny
C3 1.4 petrol (SWMBO)
lancia58
(Donor 2022)
x 8
Hi
The 4011 47 is some kind of Cylinder it is not a bush
Zohar
x 94
Zohar
Kenny says the bush's are not listed as a separate part, the part No. he posted is for the complete power steering ram/cylinder
i have sent you a pm. though which you might find interesting, regarding your car in general
Regards, malcolm.
x 94
ps.
the correct part No. for the complete power steering ram for your chassis/VIN No. is
4005 A2
POWER STEERING CYLINDER
REP X1C
although you probably dont want to go there
00004005A2 CYLINDER 261.74 GBP 314.09 GBP 314.09 GBP
Regards, malcolm.
lancia58
(Donor 2022)
x 8
Hi
Thanks Malcolm. That means that Citroen doesn't sell the bushes for the 4005 A2 ?
Zohar
SterkeYerke
x 7
Unread post by SterkeYerke »
Replying to a really old topic here, but I've got the same issue and this thread still pops up at the top on google. The part number is 4059 10. This should also be the correct bush for an XM, Saxo, 106, 405 and 406.
