c5 steering problem
c52002
c5 steering problem
Unread post by c52002 »
Hi Guys, got a problem with my c5 mark 1 I have noticed that if have the car on full lock, either left or right hand turn, the left tyre sounds as if it is seriously scrubbing. Only two days ago I noticed that when i repeated this manouver the tyre jumped from under the car and made a hell of a noise? It is as though the wheels are not aligned correctly when turning !!! But recently I had the wheel allignment checked and it was spot on ?
Any ideas? Cheers Kev.
x 1240
Re: c5 steering problem
Unread post by Peter.N. »
They do that.
Xantidote
x 5
Unread post by Xantidote »
I never like using full lock for any longer than absolutely necessary
Martin
1995 Xantia TDLX (deceased :( )
c52002
problem solved.
I took it to a performance car centre which uses very precise allignment tools. they found out that the passenger side was towing in by 4 degrees and the drivers side by 1degree. Now it corners perfectly, even on full lock! No scrubbing.
