307 hdi cooling fan
johntom
307 hdi cooling fan
Unread post by johntom »
Hi
Our 2005 307 1.6 hdi had an issue with the cooling fan running on full speed after switch off. In November the dpf split and fell down in the undertray leaving my other half stranded on the side on the road (see post 1.6 hdi dpf replacement). I replaced the Dpf with a new one, reset the counters and all has been well until today. After a 15 mile motorway journey the cooling fan has started to run on after switch off, help again !!
Lighty
x 34
Re: 307 hdi cooling fan
Unread post by Lighty »
Best to read the faults on planet, could be a number of things responsible
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
johntom
Hi
The only faults are p1351 heater plug circuit.... and 1 for Egr which as been blanked off causing the code?
Gibbo_Wirral
Unread post by Gibbo_Wirral »
Its the glow plugs, they're instrumental to a regen.
Replace the plugs and then remove and clean the terminals on the glow plug relay.
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
johntom
Hi
Thanks for that, whereabouts is the glow plug relay ?
