Xantia MK 2 - Power steering RAM
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
What are the symptoms of a bad power steering RAM ?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
Mandrake
x 695
Re: Xantia MK 2 - Power steering RAM
Unread post by Mandrake »
You might do better if you describe what symptoms you're experiencing and see if they match your the suspicion of a power steering problem, rather than asking all of the possible ways that power steering ram might fail and what the symptoms would be! :)
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
lancia58
(Donor 2022)
x 8
On lightly rough road the steering wheel turns from side to side. I also have a Citroen C4 that in the same road the steering wheel does not turn.
Zohar
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Two completely different cars and completely different pas systems. Yes they are both rack and pinion but the xantia is mechanical pas amd hydraulic syspension which is what I THINK causes the wheel "rock" .. i know exactley what you mean i get it on mine.. and the c4 is electric pas with no hydraulic suspension.. if not then a possible track rod joint worn or bottom ball joint??
A very sad...
1994 XM 2.1 d auto
