C5 x7 fault
mooseshaver
C5 x7 fault
Unread post by mooseshaver »
Hello. Occasionally when trying to use cruise control it flashes at me and won't work until engine off and on.
My non dealer hooked it up and cleared the fault of incorrect speed from ABS.
It's happened again and my Dashcommand app just says P11AB unknown diagnostic trouble code.
I can't take it to the Citroen dealer as I tried almost 12 months ago (been fine in between) and they said no fault found. Which I can't believe.
Am I going to have to buy a diagbox and find an Xp laptop?
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
jgra1
(Donor 2021)
x 36
Re: C5 x7 fault
Unread post by jgra1 »
must be someone near you moose? otherwise £70 and a cheap netbook etc..
qprdude
x 14
Re: C5 x7 fault
Unread post by qprdude »
I got that at the tail end of my last Surrey to Aberdeenshire jaunt. Switched off to come through Aberdeen city, and it wouldn't engage afterwards. Stopped the car to get some shopping about 5 miles from home and when I set off again, cruise and limiter both working. It hasn't happened again, but I don't use it a lot as most of journeys are local.
When it stopped working, it kept showing the message(s) "Speed Limiter Paused", and "Cruise Control Paused" when I tried to operate them.
Rick.
2013 Citroen DS 5 D/Sport
mooseshaver
Re: C5 x7 fault
When mine appears it's not got a speed set yet so the -- flash where speed would be.
Gone cars.
mooseshaver
Re: C5 x7 fault
jgra1 wrote:must be someone near you moose? otherwise £70 and a cheap netbook etc..
There is a MikeD in thursby. I didn't notice before
Gone cars.
qprdude
x 14
Re: C5 x7 fault
mooseshaver wrote:When mine appears it's not got a speed set yet so the -- flash where speed would be.
Yeah, mine did that but also the message "Paused" came up
Rick.
mooseshaver
Re: C5 x7 fault
I can't remember. Paused is there a lot.
Now that you mention it it's making me think it did say that.
Gone cars.
qprdude
x 14
Re: C5 x7 fault
I tried the "off" button the "on" button and the "pause" button several times with no change.
I tried flicking the clutch and brake pedals, as a known fault on some cruise systems is a sticky switch behind them.
My brothers Audi cruise stopped working and it was the switch behind the brake pedal. He got a new one for under £20. Don't know if Citroens suffer from this.
Rick.
mooseshaver
Re: C5 x7 fault
qprdude wrote:I tried the "off" button the "on" button and the "pause" button several times with no change.
My brothers Audi cruise stopped working and it was the switch behind the brake pedal. He got a new one for under £20. Don't know if Citroëns suffer from this.
I think they can suffer from this. And if I try to engage the cruise while pressing the break you get the same symptoms.
Gone cars.
jgra1
(Donor 2021)
x 36
Re: C5 x7 fault
I know mine is much older.. happened to me last week for first time. was ok again after a restart,,, maybe a switch going west
mooseshaver
Re: C5 x7 fault
jgra1 wrote:I know mine is much older.. happened to me last week for first time. was ok again after a restart,,, maybe a switch going west
what reg is yours?
Gone cars.
jgra1
(Donor 2021)
x 36
Re: C5 x7 fault
way old, just happened for first time last week.. mine is not an x7
anyway, hope you get it sorted.. I use it as often as I can really
mooseshaver
Re: C5 x7 fault
After being cleared that fault did not come back and dashcommand does not show any. But the garages diag shows faults I've put in another post. So intermittent faults and ghost faults. Hoorah.
Gone cars.
miked
x 6
Re: C5 x7 fault
Unread post by miked »
I do have a lexia clone. Used it last week to confirm the 807 "unblock diesel filter" message really does mean the DPF needs a hole through it's head. :cry:
Moose: PM me if you want.
mooseshaver
Re: C5 x7 fault
Thanks for that. Maybe after the Christmas rush?
It's settled down for now
Gone cars.
