306 HDI fault
mark21td
306 HDI fault
Unread post by mark21td »
Hi All
Not been on here for a good while, but I'm now having problems with my daughters 306.
it starts but cuts out 100yards down the road, it will restart but does the same afterwards.
it has also stalled on tickover and was very hard to start after.
We've had the codes read and have three faults logged
P1521 clutch sensor (I don't think this is causing the problem)
P1138 fuel pressure regulator
P1112 fuel rail pressure
A search on here shows that fuel pressure regulator is on the HP pump, but I've read elsewhere that these can't be changed.
I've also been advised that changing the HP pump will fix it.
What do you guys think ?
It's a 2001 HDI 90 meridian with 140K, it has run on my biodiesel but mostly on pump diesel.
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
x 1240
Re: 306 HDI fault
Unread post by Peter.N. »
If it starts OK when hot it probably won't be the HP pump, doe's it have an in tank pump? if so that could be failing.
mark21td
Re: 306 HDI fault
I've just changed the fuel filter just in case it made any difference, but it's just the same.
After driving it myself I've noticed that it will cut out as the revs rise while driving, but if you keep the revs down low and in a low gear it's fine.
x 1240
Re: 306 HDI fault
Could well be the filter then.
Sorry, didn't read the post properly :oops:
mark21td
Re: 306 HDI fault
Peter.N. wrote:If it starts OK when hot it probably won't be the HP pump, doe's it have an in tank pump? if so that could be failing.
My wife's car is a 406 2L HDI 90 Bosch pump, the same engine as the 306, so I'll see if I can swap the in tank pumps over to see if that works.
mark21td
Re: 306 HDI fault
Peter.N. wrote:Could well be the filter then.
It's not the filter as I've just changed that.
mark21td
Re: 306 HDI fault
Could it be the small filter on the in tank pump getting blocked up ?
mark21td
Re: 306 HDI fault
I've taken the in tank pump out and the filter / strainer is clean.
mark21td
Re: 306 HDI fault
Something I forgot to mention is it runs one for a few seconds after removing the key.
x 1240
Re: 306 HDI fault
My C5 does that and I have changed the pump! Its also stuck in permanent limp home mode, won't go over 3000 rpm, that doesn't bother me in the least. Let us know how it goes with the pump.
BX
x 19
Re: 306 HDI fault
Unread post by BX »
Cutting out and running on after the ignition is turned off sounds like a blocked filter on the regulator. If both cars have Bosch systems swap the regulator unit. . One electrical plug and two torx screws. The filter cannot be cleaned.
x 1240
Re: 306 HDI fault
Yes, I still have the old pump, I will try the effect of swapping the tank pump first as that's an easier job, if that fails I will try the regulator.
demag
x 102
Re: 306 HDI fault
Unread post by demag »
Egr or blocked cat?
Sent from my HUAWEI P6-U06 using Tapatalk
Dave
mark21td
Re: 306 HDI fault
BX wrote:Cutting out and running on after the ignition is turned off sounds like a blocked filter on the regulator. If both cars have Bosch systems swap the regulator unit. . One electrical plug and two torx screws. The filter cannot be cleaned.
http://s630.photobucket.com/user/tullyc ... 6.jpg.html
I'll try this but not with parts from my wife's car as she's not keen on me swapping parts about.
However I have someone sending me a new regulator and pressure sensor for this reason.
mark21td
Re: 306 HDI fault
I have a replacement pump turning up tomorrow (hopefully), so with any luck I'll let you know how It went tomorrow night.
