Hi All, my Citroen Xantia Estate HDI has just developed a strange problem. When you activate the front washer jets the water now squirts out the front and the rear jets at the same time. They also have less pressure?
Can any one tell me how they work, is there a valve for front and rear jets or a non reutrn valves etc? so i can have a look over the weekend
Just had the same problem on a ford, you need a new washer motor, one does both front/rear sets, when a bit worn it does both simultaneously.
