after a customer of mine had a replacement alternator fitted to her 05 1.4 8V C3
it has acquired a random misfire on all cylinders,
the fault code are
P0300
and
P1336
the first one i think is a ling standing code which no one seems to be able to get to the bottom of,
the second one on a gooogly search says it could be various items at fault, like crank sensor, lambada sensor or the car,
anyone have any ideas,
i did a resistance test on the crank sensor off the car which reads 500 ohms, were my Autodata software says it should read 450
05 C3 after replacement alternator
- x 94
Regards, malcolm.
uncle buck
- x 10
Re: 05 C3 after replacement alternator
Had a simular problem a lot of years ago on a mk3 astra.
It had a misfire that we just couldn't get to the bottom of, an auto electrician that was there to do a job on a different car had a quick look at it and after connecting various meters etc to it said it was the Alternator. We had checked the voltage from the alternator which seemed fine. Anyway the Alternator was changed and lo & behold the misfire was gone.
The auto electrician had gone by the time the Alternator was changed ....Wish I had took more notice or maybe even quizzed him to what it was he was testing.
Cheers.
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
Mandrake
- x 694
He was probably measuring the battery voltage on an oscilloscope looking for AC ripple - a failed diode (among other things) in the alternator can cause far more ripple on the charging voltage than there should be - although what a "normal" figure for ripple is on the average car alternator I'm not sure. Ideally you would measure it directly on the charging terminal on the alternator but you could also measure it at the battery posts, although the ripple reading will be smaller there.uncle buck wrote:Had a simular problem a lot of years ago on a mk3 astra.
http://www.pvv.org/~syljua/merc/TooSeptST07.pdf" onclick="window.open(this.href);return false;
Interesting that enough ripple can cause an intermittent misfire though!
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
uncle buck
- x 10
Thanks fo that.....every day's a School day
Cheers.
Cheers.
- x 94
whoooops i must had miss typed the P0300 into the gooogly search, as it comes up relating to a misfire now,
had another guy/freind check it out with his all singing and dancing Bosch analyer, which says its the cat at fault
Regards, malcolm.
