series 1 Xantia keys
mirafioriman
Unread post by mirafioriman »
After killing one key the replacement has now died. I've located the issue. The microswitch pins need resoldered. I can see why this happens the pressing of the switch over time flexes the pins and weakens the solder joint.
Any ideas? After resoldering I thought about supporting the switches with resin to stop them moving when pressed.
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
Mandrake
x 695
Re: series 1 Xantia keys
Unread post by Mandrake »
Just build up the solder a bit more into a fillet when you resolder them and make sure the switch body is resting against the board properly so the solder isn't taking all the strain.
Like many PCB's the original quantity of solder is too small and thin to provide enough mechanical strength.
I resoldered my S1 fob like this and it was still working perfectly 4 years later when the car was sold.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Xantidote
x 4
Unread post by Xantidote »
I've resoldered various joints on the plipper, at different times, but it's not been 100% successful - just had another go. I'm wondering if the contacts in the micrswitch have become a bit iffy. Anyone actually replaced the microswitches?
Slightly related, but I had to replace a very similar microswitch in the toaster not long ago. Admittedly in that case, it's very exposed to the heat from the toaster's elements.
Martin
1995 Xantia TDLX (deceased :( )
isisalar
x 3
Unread post by isisalar »
I recently got a repair kit for the Saxo plipper on e bay for about a tenner. Comprised of a new case, new battery and two micro switches. Should be able to get one for the Xantia I'd think.
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
mirafioriman
Well it's fixed :)
I have re-soldered the four pins (and replaced the batteries) and it's now working fine. For how long remains to be seen.........
