C5 Facelift model headlight washers stuck out :!:
Diabolical
Unread post by Diabolical »
My C5 06 facelift exclusive model headlight washers have come out and won't retract :?:
Tried switching headlights on and using screen wash to no avail :?:
Any C5 owners had this problem and how to solve it :?: wondering if could be sorted using Lexia :?:
David
06 C5 2.0L HDi Exclusive Estate 20020k and rising. :-)
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
qprdude
x 14
Re: C5 Facelift model headlight washers stuck out :!:
Unread post by qprdude »
Not frozen are they? Spray lube. BSI reset?
Rick.
2013 Citroen DS 5 D/Sport
Diabolical
qprdude wrote:Not frozen are they? Spray lube. BSI reset?
Not frozen, tried lube, best I get Lexia on to it I suppose.
I didn't even know it had them I thought they was blanking plates. :rofl2:
citroencx.co.uk
x 2007
Unread post by Stickyfinger »
thought they always stuck out when its cold !.....ohhh matron !
Diabolical
Stickyfinger wrote:thought they always stuck out when its cold !.....ohhh matron !
:lol: :lol: :lol:
Sorted: had a friend do windscreen wash I managed to push them back in when they stopped squirting, hope I don't have to do that each time.
David
citroencx.co.uk
boristhespie
x 4
Unread post by boristhespie »
Oit of curiosity do they spray automatically when you spray the windscreen or do you have to do something else?
C'est pas possible!
qprdude
x 14
With the screen washers
Rick.
kenhall1202
Unread post by kenhall1202 »
Had this problem on one of my C4 headlight washers following prolonged hard frost a few winters back. I baulked at paying over £50 for a new one from Citroen so bit the bullet and dismantled it (front plastic valance/bumper has to come off to get at them on the C4). Basically the spring and internal gubbins had come adrift probably due to frost expansion however nothing was broken. It has been OK since but there is still the 'stiction' problem where the washers don't fully retract after use. My XM does the same.
On the C4 the headlight washers operate with the screen washers but only when the lights are on.
Ken
Ken Hall
radoica
Unread post by radoica »
I have problem with my headlight washers on C4 2006.
When they go out, left one spray on headlight, but right one just go out, nothing go out of it.
Anyone know what could be problem here?
dnsey
x 19
Unread post by dnsey »
Well, they are operated by the water pressure, so it's likely to be just a blocked jet.
SaabC5
Unread post by SaabC5 »
If they are anything like Saab headlamp washers they will be pressure operated only when the headlamps are on and the screen wash activated. What tends to happen is the plastic piston drys up over time and tends to stick in the up position. Try cleaning the piston and giving a liberal spray of silicon spray and operating the washers a few times to loosen up the piston again. You'll find you will probably need to repeat lubing every 6-8 months to keep them working.
