406 Cooling Fan
evilally
x 3
406 Cooling Fan
Unread post by evilally »
Arrrggh.....I'm fitting a new AC condenser and thought I'd investigate why one cooling fan isn't working while it's in bits. When I disconnect the brown temp sensor in front of the fuel filter housing, one fan kicks in at high speed (12v output on plug). The other fan doesn't spin at all, no output at plug. The 3 green relays are new. All 3 make a small *click* when I disconnect the temp sensor, then the top 2 make a louder *click* as the fan kicks in. I have wiggled and flexed the wire to the non-turning fan to try and check for a break. My electrical skills are poor I would say so I'm not sure where to go from here. I've now got to try and get the car back together to go to work tomorrow, could be a late one! :( Can anyone advise on the next step of troubleshooting?
'97 406 1.9TD, 314k.
evilally
x 3
Re: 406 Cooling Fan
Problem solved! I found a blown 40 amp fuse in the fuse box next to the battery.
Useful fan troubleshooting links:
http://www.peugeotlogic.com/workshop/ws ... fanop1.htm" onclick="window.open(this.href);return false;
http://www.peugeotlogic.com/fuses/fuses406/fuses1.htm" onclick="window.open(this.href);return false;
