hi
i am looking ar cylinder heads for 2.2 hdi c8
i will need to take my head off as one of the bolts holding top engine mount in to head has snapped off and stuck down in head
i am thinking worst, i could end up needing new head
but would head from c5 2.2 hdi,607 2.2hdi, fit c8 hdi? my engine code taken from v5 is
variant eb4hw
version eb4hwg
so i think my engine code is hw?
they are diffrent engine codes?
what could be a diffrence in heads??
rang pug and they would need shassies number from donor car to say it would or not fit?
i hope my broken bolt will be sorted one taken out nice,but knowing my luck i will need a head!
dont worry my injectors are nice and free,they get taken out evry 6 month and re greased to stay free!
any help or ideas please?
thank you
2.2 hdi engine codes
SaabC5
Re: 2.2 hdi engine codes
My C5 engine variant is DW12TED (fap) for a 2002 model, don't forget the later 2.2HDi is a twin turbo model so totally different set up to the 1st gen 2.2
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
- x 1240
Can you actually get to the broken piece of bolt? if so weld a nut onto it, if its flush with the head just weld down the centre of the nut. I had this happen on my C5 2.2 but fortunately it came out OK.
dragon
hi
thanks for replay
dw12ted is main code,they all are
then you have
hw
hx
and few more
same dw12ted is fitted in 607hdi and c5hdi,c8,807hdi 406hdi but most of them have diffrent engine code
but cant find any info what is the diffrence in codes
if i make any sence
car is half way apart, injectors,rail etc off
all done and removed part from timing belt side ,
dont want to do that outside house, will push it in back garden just waiting for scafolding to be moved
then i will see ,i am hoping broken bit of bolt can be re drilled and taken out and tread saved
will see what nut and bolt man got to say
it could end up coil job and new bolt
will need new maunt bracket as the broken bolt was just spining round and eaten tread up
what i was thinking is if i need head
dose numbers and casting numbers of heads matter?
mine is casting v35 dont know long number on top of my head
some heads i seen casting v55
but i cant find any info what the diffrents in them are!
thank you
thanks for replay
then you have
hw
hx
and few more
if i make any sence
thank you
