xantia heater matrix
hubcap
hi all, Is it possible to disconnect the heater matrix hose from my xantia 1.8 sx to enable me to flush it out without removing any part of the cam shaft cover?
t4xi
wrinklet1
The design of heater matrix is crap, vertical instead of horizontal, therefore fills up with sediment. Try this first, remove the bottom hose from your radiator, then remove the thermostat, put your hosepipe into the stat housing and make sure the heater is open, allow the water to back flow for around 20 mins, this may dis lodged the crap if your lucky.
