Xantia II - Replacing broken power window regulator
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
I replaced a broken power window regulator( front window ) . The still wires were OK. When I put all together ( with the new regulator ) it looks like the wires are a bit lose and when lowering the window the wire slips out of the top poly. I tried to figure it out since before the regulator broke with the same wires it was OK and now the wires a bit lose. Nay one did it before and can advise ?
P.S. I got a new repair kit and have the same problem of lose still wires, I guess I do something wrong?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
MJM
Re: Xantia II - Replacing broken power window regulator
Unread post by MJM »
The tensioner on the bottom should be nearly fully compressed if you have the cable run properly worked out. I've some photographs about somewhere if you think that they will help. The cable drum should have all of its grooves full of cable.
Post back if you want the photos.
MJM
MJM
1999 Dante red Xantia Exclusive 2,0 petrol. No smelly diesel for me. Now re-homed
2007 Wicked Red C5 Exclusive. Now a smelly diesel automatic for me.
lancia58
(Donor 2022)
x 8
Hi
Please post the pictures. When installed the wires the tensioner was half compressed. I guess it is related to the still wires length, but as the kit is new the wires are new. The thing is that before the regulator broke with the same wires it was OK and after replacing to the very same regulator it looks like the wires are lose
Zohar
MJM
Try this
http://www.flickr.com/photos/77195466@N05/" onclick="window.open(this.href);return false;
MJM
