Hello folk, I've had a truck reverse turn and crush my driver side front wing. It appears the outer wing is simply bolted on: is replacement only a matter of unbolting and re-bolting, plus sealant?
Experienced tips appreciated.
Thanks in advance, John.
Sent from a mobile transmitter.
Xantia wing replacement procedure
John Plum
- x 5
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
Timmo
- x 168
Re: Xantia wing replacement procedure
yup! there are the obvious bolts along the top of the wing in the bonnet shut area, a couple of bolts on the cross member/slam panel end, there's one in by the indicator and another tucked in half way in the area, takes a while to get out due to limited movement of ratchet spanner/wrench, the arch liner screws/bolts put a remarkably strong fight in to holding it all on too!!! there are a couple of bolts in the passenger door hinge and one Underneath on the sill, the sealant is quite strong but it the wings knackered then not too much bother in being a bit forceful in removal, iirc they are all 10mm bolts?? took me quarter of an hour to get mine off first time, most the time spent on the one that's in the indicator whole area!!
also make sure you move the side repeater loom too, and poke it back out the whole int he replacement wing before bolting it all back on!
i'd say removal and replacement job is about half an hour for a confident sparnnerman!
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
John Plum
- x 5
Cheers Timmons, sounds easy enough, then. Great.
John Plum
oscar
- x 8
hi don't forget you have to remove bumper also there a bolt up inside wing on each side which can have lost captive nuts locking so when undo will just spin i glued nine back in with like araldite.
John Plum
- x 5
Cheers Oscar
Sent from a ??????? transmitter.
John Plum
