This is my first post, so hello. I had the unfortunate opportunity to disassmble my ZX last week due to a haed gasket failure:-( Planning to put it back together tomorrow hence the post with some questions!
I am due to put my camshaft back in after a head gasket failure. The haynes manual says to put sealing compound on several surfaces on the end bearing caps, my question is really what compound to use? I have some Hermetite Gold (non hardening gasket compound) but should i be using Hermetite orange (hardening gasket compound)?
Also, the head gasket removed is a 2 notch gasket, if the head has been skimmed should i put a 3 notch one on?
If anyone has an opinion?
Cheers, Mark
zx camshaft bearing caps
oilyspanner
spanner 1
zxdyson
