C5 blower burn-out
Tully
C5 blower burn-out
Unread post by Tully »
Hi Folks
I have a recurring problem with my C5 2.2 hdi fan blower.
The connectors for the blower keep melting meaning no fan and fogged up windows.
I've used a local auto electrician twice who has replaced different connectors with heavy duty connector block but now it has happened again :x , probably somewhere hidden deep inside the dashboard.
Can anyone make any suggestions about how to overcome this pain in the backside?
Craig
C5 2.2 hdi exclusive semi-auto
Seat Alhambra 1.9 tdi (Cavey-mobile)
GPZ750R modified (for sale)
Missing my Saab 9-3
Mandrake
x 695
Re: C5 blower burn-out
Unread post by Mandrake »
Have you replaced the fan ? A faulty fan that is for example partly seized may draw a lot more current than normal, if a more beefy replacement connector has also melted excessive current drain is really the only likely cause.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Tully
Mandrake wrote:Have you replaced the fan ? A faulty fan that is for example partly seized may draw a lot more current than normal, if a more beefy replacement connector has also melted excessive current drain is really the only likely cause.
Hi Mandrake. The replacement connectors are holding out, it's the feeble standard Citroen ones that are melting one at a time. As for replacing the fan, now you mention it, it does squeal slightly on medium settings, maybe not turning as freely as it should. Is replacement an easy job?
Craig
Missing my Saab 9-3
Clogzz
x 40
Unread post by Clogzz »
The blower motor will draw high current if the pollen filter is blocked.
It's tucked high up at the front of the centre console, on the passenger's side.
Item 10 in the picture:
Tully
Clogzz wrote:The blower motor will draw high current if the pollen filter is blocked.
Thanks Clogzz.
I've been researching to see how easy it is to change the filter and it doesn't look too difficult. Maybe I can whip out the fan motor itself and hit it with some spray lubricant as well. By the way, what is item number 3 in your diagram? it looks like a filter as well....
Craig
Missing my Saab 9-3
electronmirror
x 30
Unread post by electronmirror »
Item 3 is actually the fan :)
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
Tully
Nice one, Clogzz. Thanks.
Craig
Missing my Saab 9-3
electronmirror
x 30
Er.... not Clogzz :-D
Had similar problems with this fan on my Xantia, poor quality Citroen connector were to blame. Decent replacements sorted the issue. Incidentally the fan on mine draws 20A when running full speed so quite understandable that connectors were getting hot.
Ted
Tully
Sorry Electronmirror #-o ....thanks for your input.
Craig
Missing my Saab 9-3
Monkeyfeet
(Donor 2022)
Unread post by Monkeyfeet »
Top photo bucket library of useful Citroen stuff Clogzz! =D> Couldn't help browsing through it. I've been collecting a photos and putting them on photobucket (other libraries available...) too. Worth adding links in signatures maybe? And apologies for wandering off-topic.
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
x 5674
Monkeyfeet wrote:Top photo bucket library of useful Citroen stuff Clogzz! =D> Couldn't help browsing through it. I've been collecting a photos and putting them on photobucket (other libraries available...) too. Worth adding links in signatures maybe? And apologies for wandering off-topic.
There is the "Useful Links" forum that is tailor made for such items. It would indeed be great to have such a collection of photo's and drawings all in one place.
There is such a phenomenal amount of useful information on the forum it would be nice to organise it as a database - which it is, I suppose, but lacking the 'organise' part. The information, though somewhat organised into forums is still rather disparate and many questions are repeated endlessly.
On the other hand it wouldn't do to have Citropaedia and miss out on all the peripheral chat that makes this place what it is.
