as u can see mine needs replaced, is the cracked part a bearing and are they available to buy?
citronut wrote:here is price and part No. for one MK1 Berlingo strut mount bearing
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000503527 THRUST BEARING 22.17 GBP 26.60 GBP 26.60 GBP
but if you send me the last 8 digits of your chassis/VIN No. i will check for specific to that
From bitter experience I'd recommend replacing the entire top mount as well as the thrust bearing.citronut wrote:citronut wrote:here is price and part No. for one MK1 Berlingo strut mount bearing
dont order the above bearing till its checked against your chassis/VIN No.
kenhall1202 wrote:I hope you bought two bearings - in my experience they both failed within a few months of eachother.
They make creaking or cracking noises, or in my case, a weird metallic rattling when going over roughish roads (but oddly not speed bumps). The roads, especially the kerb side around here are so rough that in the last 3 years, my Berlingo has had a 2 new passenger side strut tops and bearings, a spring,droplink, a strut and a bottom arm and bushes. The right hand side has had nothing.john wrote:kenhall1202 wrote:I hope you bought two bearings - in my experience they both failed within a few months of eachother.
how do u know when they've failed?
Maybe the balls have created indentations in the bearing surfaces, so the rotational movement is no longer smooth?john wrote:the spring will follow the shock round so far stop then jump back round, its like its catching on something.
